주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus Zenbook UX32VD HD Web Camera Replacement
필요한 것
  1. Asus Zenbook UX32VD  HD Web Camera Replacement, HD Web Camera: 1 단계, 이미지 1개 중 1개
    • Heat the adhesive behind the screen frame with a hair dryer or a heat gun.
    • Use low heat with the heat gun. Over heating could damage delicate electronic components.
  2. Asus Zenbook UX32VD  HD Web Camera Replacement: 2 단계, 이미지 3개 중 1개 Asus Zenbook UX32VD  HD Web Camera Replacement: 2 단계, 이미지 3개 중 2개 Asus Zenbook UX32VD  HD Web Camera Replacement: 2 단계, 이미지 3개 중 3개
    • Insert a spudger between the display screen frame and the back screen panel.
    • Pry the display screen frame away from the back screen panel.
    • Continue to heat and remove the display screen frame along the whole perimeter.
  3. Asus Zenbook UX32VD  HD Web Camera Replacement: 3 단계, 이미지 3개 중 1개 Asus Zenbook UX32VD  HD Web Camera Replacement: 3 단계, 이미지 3개 중 2개 Asus Zenbook UX32VD  HD Web Camera Replacement: 3 단계, 이미지 3개 중 3개
    • Remove display screen frame completely before adhesive cools and hardens.
  4. Asus Zenbook UX32VD  HD Web Camera Replacement: 4 단계, 이미지 2개 중 1개 Asus Zenbook UX32VD  HD Web Camera Replacement: 4 단계, 이미지 2개 중 2개
    • Unplug the bundled cable connector.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  5. Asus Zenbook UX32VD  HD Web Camera Replacement: 5 단계, 이미지 3개 중 1개 Asus Zenbook UX32VD  HD Web Camera Replacement: 5 단계, 이미지 3개 중 2개 Asus Zenbook UX32VD  HD Web Camera Replacement: 5 단계, 이미지 3개 중 3개
    • Pry the camera out from the two pins on the left and right of the camera with the tip of a spudger.
    • Remove the camera completely.
결론
작성자
1다른 기여자 명과 함께
Michael Remmel
회원 가입일: 09/17/15
718 평판
안내서 3개를 작성함
CSU Fullerton, Team 2-2, Bruce Fall 2015 CSU Fullerton, Team 2-2, Bruce Fall 2015 회원
CSUF-BRUCE-F15S2G2
4 회원들
안내서 6개를 작성함
2가이드 댓글
what type/model/code for its replacement camera ? so i cant find it in part store...
tukangsedot - 답글
Thank you for the demo. It appears to be easy to replace the camera per your instructions. Kind regards. Mehran Gerami
Mehran Gerami - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 17
전체 시간: 2,110
