소개
If the HD web camera is not functioning this guide will teach you how to get behind the screen cover to replace the camera.
Note: Be sure the camera is broken and not just a software issue before you replace it.
필요한 것
Insert a spudger between the display screen frame and the back screen panel.
Pry the display screen frame away from the back screen panel.
Continue to heat and remove the display screen frame along the whole perimeter.
Pry the camera out from the two pins on the left and right of the camera with the tip of a spudger.
Remove the camera completely.
2 Comments
what type/model/code for its replacement camera ? so i cant find it in part store...
Thank you for the demo. It appears to be easy to replace the camera per your instructions. Kind regards. Mehran Gerami
