주요 콘텐츠로 건너뛰기
Asus Zenbook UX32VD HD Web Camera Replacement
필요한 것
  1. Asus Zenbook UX32VD  HD Web Camera Replacement, HD Web Camera: 1 단계, 이미지 1/1
    • Heat the adhesive behind the screen frame with a hair dryer or a heat gun.
    • Use low heat with the heat gun. Over heating could damage delicate electronic components.
  2. Asus Zenbook UX32VD  HD Web Camera Replacement: 2 단계, 이미지 1/3 Asus Zenbook UX32VD  HD Web Camera Replacement: 2 단계, 이미지 2/3 Asus Zenbook UX32VD  HD Web Camera Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Metal Spudger Set
    $7.99
    구매
    • Insert a spudger between the display screen frame and the back screen panel.
    • Pry the display screen frame away from the back screen panel.
    • Continue to heat and remove the display screen frame along the whole perimeter.
  3. Asus Zenbook UX32VD  HD Web Camera Replacement: 3 단계, 이미지 1/3 Asus Zenbook UX32VD  HD Web Camera Replacement: 3 단계, 이미지 2/3 Asus Zenbook UX32VD  HD Web Camera Replacement: 3 단계, 이미지 3/3
    • Remove display screen frame completely before adhesive cools and hardens.
  4. Asus Zenbook UX32VD  HD Web Camera Replacement: 4 단계, 이미지 1/2 Asus Zenbook UX32VD  HD Web Camera Replacement: 4 단계, 이미지 2/2
    • Unplug the bundled cable connector.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  5. Asus Zenbook UX32VD  HD Web Camera Replacement: 5 단계, 이미지 1/3 Asus Zenbook UX32VD  HD Web Camera Replacement: 5 단계, 이미지 2/3 Asus Zenbook UX32VD  HD Web Camera Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Spudger
    $2.99
    구매
    • Pry the camera out from the two pins on the left and right of the camera with the tip of a spudger.
    • Remove the camera completely.
결론
Michael Remmel
회원 가입일: 09/17/15
709 평판
안내서 3개 작성하였습니다
CSU Fullerton, Team 2-2, Bruce Fall 2015 CSU Fullerton, Team 2-2, Bruce Fall 2015 회원
CSUF-BRUCE-F15S2G2
4 회원들
안내서 6개 작성하였습니다
댓글 2개
what type/model/code for its replacement camera ? so i cant find it in part store...
tukangsedot - 답글
Thank you for the demo. It appears to be easy to replace the camera per your instructions. Kind regards. Mehran Gerami
Mehran Gerami - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 8
전체 시간: 1,866
