소개
Use this guide to replace old batteries in your Asus Zenbook UX32VD to get longer battery life!
필요한 것
Remove the twelve 3 mm bottom panel screws with a T5 Torx Screwdriver.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 5개
what is the color code of the battery wiring? especially for the white and yellow
Asim Ahmed - 답글
Will this method also apply to ASUS Zenbook UX430UQ ?
Is this the same method for ASUS Zenbook UX430UQ-GV050T ?
this is probably odd, but can someone recommend me battery and speakers?
I did small research, have not found any speakers and found a few options with battery, but all of them looks suspicious, some comments like - dead after 1 year and etc...
Regards
Nikolay Em - 답글
Why would you replace the speakers? I don't ever understand, why would you unplug the speakers (as it's done in these instructions)? They are just taped on side of the battery, once you lift up the battery a little bit, you can take the speakers off from the battery pack and leave them on their place while replacing the battery.
