소개
Use this guide to replace old batteries in your Asus Zenbook UX32VD to get longer battery life!
도구
부품
지정된 부품이 없습니다.
Remove the twelve 3 mm bottom panel screws with a T5 Torx Screwdriver.
Remove the battery completely.
Battery replacement is pretty easy procedure for Asus Zenbook series. You also can check on my video how to replace the motherboard, which is more complex, but can be accomplished with mid level of experience.. https://www.youtube.com/watch?v=jJLl5DhY...
Even the video is for another model, you still can apply the same technique to another models from Zenbook series.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 4개
what is the color code of the battery wiring? especially for the white and yellow
Asim Ahmed - 답글
Will this method also apply to ASUS Zenbook UX430UQ ?
Is this the same method for ASUS Zenbook UX430UQ-GV050T ?
this is probably odd, but can someone recommend me battery and speakers?
I did small research, have not found any speakers and found a few options with battery, but all of them looks suspicious, some comments like - dead after 1 year and etc...
Regards
Nikolay Em - 답글
