주요 콘텐츠로 건너뛰기
Asus Zenfone 3 Zoom Battery Replacement
필요한 것
  1. Asus Zenfone 3 Zoom Battery Replacement, Battery: 1 단계, 이미지 1/2 Asus Zenfone 3 Zoom Battery Replacement, Battery: 1 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using a pair of tweezers, pull put the SIM card tray and set it to the side.
  2. Asus Zenfone 3 Zoom Battery Replacement: 2 단계, 이미지 1/1
    • Remove the two 2 mm screws using a Torx T2 screwdriver.
  3. Asus Zenfone 3 Zoom Battery Replacement: 3 단계, 이미지 1/2 Asus Zenfone 3 Zoom Battery Replacement: 3 단계, 이미지 2/2
    • Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone.
    • There will be a thin film connecting the two pieces. You do not need to remove this. Just fold the two pieces apart with the inside facing up.
  4. Asus Zenfone 3 Zoom Battery Replacement: 4 단계, 이미지 1/1
    • Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
  5. Asus Zenfone 3 Zoom Battery Replacement: 5 단계, 이미지 1/1
    • Peel back the silver tape.
  6. Asus Zenfone 3 Zoom Battery Replacement: 6 단계, 이미지 1/1
    • Disconnect the battery connections.
  7. Asus Zenfone 3 Zoom Battery Replacement: 7 단계, 이미지 1/1
    • Pry and remove the battery.
    • The underside of the battery is adhesive so make sure to pry the battery off gently.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Joshua Fontenelle
회원 가입일: 09/10/18
241 평판
안내서 1개 작성함
University of Alabama, Team S2-G7, Bedsole Fall 2018 University of Alabama, Team S2-G7, Bedsole Fall 2018 회원
UA-BEDSOLE-F18S2G7
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 24
전체 시간: 3,857
