소개
This guide will demonstrate how to replace the battery of a Zenfone 3. This may be necessary if the battery has been damaged, will not hold a charge, or drains excessively quickly. For this guide, you will need the tweezers, Torx T2 screwdriver, a prying tool, and the Phillips #00 screwdriver.
필요한 것
Using a pair of tweezers, pull put the SIM card tray and set it to the side.
다른 5명이 해당 안내서를 완성하였습니다.
