주요 콘텐츠로 건너뛰기
Asus Zenfone 4 Max Camera Replacement
필요한 것
  1. Asus Zenfone 4 Max Camera Replacement, Camera: 1 단계, 이미지 1/1
    • Using a removable head screwdriver and a T4 bit, remove the screws on the base of the phone on either side of the charging port.
  2. Asus Zenfone 4 Max Camera Replacement: 2 단계, 이미지 1/1
    • Starting near either of the 4 corners of the device notice the seam of the case around the front of the device.
    • Begin using the opening tool with a moderate amount of force to wedge between the back case and the phone.
    • Gently move the tool around the edges towards each corner until the back is removed.
    • You will be able to hear the back casing pulling apart from the phone. Do not be alarmed, but work gently with the device.
  3. Asus Zenfone 4 Max Camera Replacement: 3 단계, 이미지 1/2 Asus Zenfone 4 Max Camera Replacement: 3 단계, 이미지 2/2
    • Using a removable head screwdriver and a PH0 bit, begin removing the panel beneath the two cameras by unscrewing the screw.
  4. Asus Zenfone 4 Max Camera Replacement: 4 단계, 이미지 1/3 Asus Zenfone 4 Max Camera Replacement: 4 단계, 이미지 2/3 Asus Zenfone 4 Max Camera Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to gently pull up on the flaps beneath the two cameras.
    • Completely remove the cameras and replace with the new cameras.
결론
Maegan West
회원 가입일: 10/02/18
839 평판
안내서 4개 작성하였습니다
Sam Houston State, Team S11-G6, Blackburne Fall 2018 Sam Houston State, Team S11-G6, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S11G6
4 회원들
안내서 10개 작성하였습니다
댓글 2개
You can read T3 in the summary and T4 in the instructions: which one do I need?
patriziomaugeri - 답글
Does this fix the Zenfone 4 max camera black screen?
Roger Dufault - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 14
전체 시간: 1,981
