주요 콘텐츠로 건너뛰기
Asus Zenfone 4 Max Charging Port Replacement
필요한 것
  1. Asus Zenfone 4 Max Charging Port Replacement, Battery: 1 단계, 이미지 1/2 Asus Zenfone 4 Max Charging Port Replacement, Battery: 1 단계, 이미지 2/2
    • Using a removable head screwdriver and a T3 bit, begin by removing the two screws located on either side of the charging port.
  2. Asus Zenfone 4 Max Charging Port Replacement: 2 단계, 이미지 1/1
    • Gently wedge the opening tool between the phone and the back casing.
    • Move the opening tool up and down to pry the back off of the device.
  3. Asus Zenfone 4 Max Charging Port Replacement: 3 단계, 이미지 1/3 Asus Zenfone 4 Max Charging Port Replacement: 3 단계, 이미지 2/3 Asus Zenfone 4 Max Charging Port Replacement: 3 단계, 이미지 3/3
    • Once the back has been removed, you will need to unscrew the four screws on the bottom panel with an AT3 bit.
  4. Asus Zenfone 4 Max Charging Port Replacement: 4 단계, 이미지 1/1
    • Remove the bottom panel.
  5. Asus Zenfone 4 Max Charging Port Replacement: 5 단계, 이미지 1/2 Asus Zenfone 4 Max Charging Port Replacement: 5 단계, 이미지 2/2
    • Wedge an opening tool between the battery and phone.
    • Gently pry the battery out of the device.
    • You can move the opening on either side of the battery as well as the bottom to aid in removal.
  6. Asus Zenfone 4 Max Charging Port Replacement: 6 단계, 이미지 1/1
    • Remove the battery and replace it with the new battery.
  7. Asus Zenfone 4 Max Charging Port Replacement, Charging Port: 7 단계, 이미지 1/3 Asus Zenfone 4 Max Charging Port Replacement, Charging Port: 7 단계, 이미지 2/3 Asus Zenfone 4 Max Charging Port Replacement, Charging Port: 7 단계, 이미지 3/3
    • Once the battery has been removed, gently wedge the metal spudger beneath the green panel.
    • Lift the panel along with the charging port out the device and replace with the new charging port.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Maegan West
회원 가입일: 10/02/18
839 평판
안내서 4개 작성하였습니다
Sam Houston State, Team S11-G6, Blackburne Fall 2018 Sam Houston State, Team S11-G6, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S11G6
4 회원들
안내서 10개 작성하였습니다
댓글 2개
repair microfone asus zenfone 4 selfie pro please
John Wesley - 답글
I have managed to replace the charging port but now it shows Charging Port Temperatures Abnormalities Reminder which is loud and annoying to see every time. I also see that one of my sensors in the cpu-z program (thermal sensor pa_therm0) hitting a constant 75-84 degree centigrade and another sensor (chg_temp) hitting 65 constantly. Any help in regards to this manner?
Max Orwell - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 10
30일 전: 22
전체 시간: 3,195
