주요 콘텐츠로 건너뛰기
Asus Zenfone 4 Max SIM Card Replacement
필요한 것
  1. Asus Zenfone 4 Max SIM Card Replacement, SIM Card: 1 단계, 이미지 1/1
    • Locate the SIM tray on the left edge of the phone.
    • There is a small hole on the outside of the SIM tray that will be used for opening the tray.
  2. Asus Zenfone 4 Max SIM Card Replacement: 2 단계, 이미지 1/2 Asus Zenfone 4 Max SIM Card Replacement: 2 단계, 이미지 2/2
    • Insert a SIM card eject tool into the hole.
    • Press until the SIM tray pops out slightly from the phone.
    • Be careful not to force any object to fit into the tray's opening hole. The object should be thin enough to fit directly into the hole.
  3. Asus Zenfone 4 Max SIM Card Replacement: 3 단계, 이미지 1/2 Asus Zenfone 4 Max SIM Card Replacement: 3 단계, 이미지 2/2
    • Once the SIM tray has been opened, gently pull the tray completely out of the phone.
    • Lift the old SIM card out of the tray with your fingers or flip the tray upside down to make the card fall out.
  4. Asus Zenfone 4 Max SIM Card Replacement: 4 단계, 이미지 1/1
    • Finally, replace the old card with the new SIM card and close the SIM tray.
결론
To reassemble your device, place the SIM tray back into the tray slot
Maegan West
회원 가입일: 10/02/18
839 평판
안내서 4개 작성하였습니다
Sam Houston State, Team S11-G6, Blackburne Fall 2018 Sam Houston State, Team S11-G6, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S11G6
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 42
전체 시간: 2,151
