주요 콘텐츠로 건너뛰기
Atari 2600 Jr. Rev. A Disassembly
필요한 것
  1. Atari 2600 Jr. Rev. A Disassembly, Remove the base: 1 단계, 이미지 1개 중 1개
    • Remove 5 Phillips screws from base.
  2. Atari 2600 Jr. Rev. A Disassembly, Detach the Case: 2 단계, 이미지 3개 중 1개 Atari 2600 Jr. Rev. A Disassembly, Detach the Case: 2 단계, 이미지 3개 중 2개 Atari 2600 Jr. Rev. A Disassembly, Detach the Case: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Heavy-Duty Spudger
    • Use a metal or heavy duty spudger to unhook the 3 plastic clips holding the front of the case together.
    • Be careful not to break the plastic clips
    • While unhooking the center hook use another spudger to run along the top and bottom casing. This helps to get the clip lose.
    • Be careful not to pull the case apart quickly, there is a ribbon that is attached to the top and bottom.
  3. Atari 2600 Jr. Rev. A Disassembly, Detach the Ribbon: 3 단계, 이미지 1개 중 1개
    • Detach the ribbon from the circuit board by gently pulling ribbon out from clip.
  4. Atari 2600 Jr. Rev. A Disassembly, Remove Circuit Board from Base: 4 단계, 이미지 2개 중 1개 Atari 2600 Jr. Rev. A Disassembly, Remove Circuit Board from Base: 4 단계, 이미지 2개 중 2개
    • There are 2 clips holding the circuit board in place.
    • Using a metal or heavy duty spudger release the clip on the left side.
    • Remove the circuit board.
결승점
다른 8명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Aislinn
회원 가입일: 12/02/16
321 평판
안내서 1개를 작성함
1가이드 댓글
Great process for dis-assembly. Now all I need is a replacement reed switch as mine is broken. Being in Australia it is very hard to find one locally. many Thanks.
Singoau - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 18
지난 30일: 67
전체 시간: 5,331
