주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Atari 5200 Controller Side Buttons Replacement
필요한 것
  1. Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: 1 단계, 이미지 3개 중 1개 Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: 1 단계, 이미지 3개 중 2개 Atari 5200 Controller Side Buttons Replacement, Controller Side Buttons: 1 단계, 이미지 3개 중 3개
    • Turn the controller over, exposing the three screws on the back. Use a 6mm screwdriver to remove these screws.
    • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
  2. Atari 5200 Controller Side Buttons Replacement, A Little Off the Sides: 2 단계, 이미지 2개 중 1개 Atari 5200 Controller Side Buttons Replacement, A Little Off the Sides: 2 단계, 이미지 2개 중 2개
    • Now that the top of the controller is exposed, the orange, side buttons can easily slide out.
    • Realign the buttons over the sensors/clean the sensor contacts.
    • Be careful when reassembling your buttons. Make sure the black buttons are aligned properly over the silver sensors on the flex board
    • Also, be careful to properly align the bottom of the joystick with the pots (white levers)
  3. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 1: 3 단계, 이미지 2개 중 1개 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 1: 3 단계, 이미지 2개 중 2개
    • Use a spudger to remove the top frame.
    • Take off the plate.
    • Remove the rubber buttons.
  4. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 2: 4 단계, 이미지 2개 중 1개 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 2: 4 단계, 이미지 2개 중 2개
    • Pull the circuit strip through the new space.
    • Realign the top and bottom of the controller.
  5. Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: 5 단계, 이미지 3개 중 1개 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: 5 단계, 이미지 3개 중 2개 Atari 5200 Controller Side Buttons Replacement, Reassembly Part 3: 5 단계, 이미지 3개 중 3개
    • Return the buttons to the top of the controller.
    • Snap the frame back into place.
    • Screw the screws.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Alan Abelson
회원 가입일: 09/26/14
233 평판
안내서 5개를 작성함
USF Tampa, Team 13-1, Staggers Fall 2014 USF Tampa, Team 13-1, Staggers Fall 2014 회원
USFT-STAGGERS-F14S13G1
5 회원들
안내서 17개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 53
전체 시간: 1,381
