주요 콘텐츠로 건너뛰기
소개
Repairing the motherboard of the Atari 5200.
  1. Flip your Atari Entertainment System over to its top so you can see the bottom.  You'll see seven screws holding your system together. Use a Philips #0 screwdriver to remove all seven screws.
    • Flip your Atari Entertainment System over to its top so you can see the bottom. You'll see seven screws holding your system together. Use a Philips #0 screwdriver to remove all seven screws.
  2. Flip the Atari Entertainment System back over so that you can now see the top.
    • Flip the Atari Entertainment System back over so that you can now see the top.
    • Use your hands to gently remove the top by sliding it off.
  3. You will now have access to the motherboard.
    • You will now have access to the motherboard.
    • The motherboard can be cleaned with a moist paper towel.
    • Be sure the motherboard is fully dry before playing your Atari Entertainment System or you may damage it!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Zach Petryszyn
회원 가입일: 2014년 09월 26일
21 평판
안내서 3개 작성하였습니다
USF Tampa, Team 13-1, Staggers Fall 2014 USF Tampa, Team 13-1, Staggers Fall 2014 회원
USFT-STAGGERS-F14S13G1
5 회원들
안내서 11개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 16
전체 시간: 1,985
