주요 콘텐츠로 건너뛰기
Atari 5200 Game Cartridge Disassembly
필요한 것
  1. Atari 5200 Game Cartridge Disassembly, Opening up the cartridge: 1 단계, 이미지 3개 중 1개 Atari 5200 Game Cartridge Disassembly, Opening up the cartridge: 1 단계, 이미지 3개 중 2개 Atari 5200 Game Cartridge Disassembly, Opening up the cartridge: 1 단계, 이미지 3개 중 3개
    • Flip the cartridge over.
    • Unscrew the single screw on the back.
    • Carefully pry apart the casing. There are six (6) tabs that need to be released, three (3) each side. If you're not careful they will break. (experience has taught me)
    • Set aside any case parts after dissassembly.
  2. Atari 5200 Game Cartridge Disassembly, Cleaning the Parts: 2 단계, 이미지 1개 중 1개
    • Unscrew the board casing, and remove it.
    • Use a compressed air can to blow off any excess dust off the board.
    • Use an alcohol-dabbed cloth to wipe down the gold-plated contacts of the board.
  3. Atari 5200 Game Cartridge Disassembly, Reassembly: 3 단계, 이미지 3개 중 1개 Atari 5200 Game Cartridge Disassembly, Reassembly: 3 단계, 이미지 3개 중 2개 Atari 5200 Game Cartridge Disassembly, Reassembly: 3 단계, 이미지 3개 중 3개
    • Place the two contact protectors together.
    • Place the spring on the knob in the cartridge.
  4. Atari 5200 Game Cartridge Disassembly, Reassembly, Part 2: 4 단계, 이미지 3개 중 1개 Atari 5200 Game Cartridge Disassembly, Reassembly, Part 2: 4 단계, 이미지 3개 중 2개 Atari 5200 Game Cartridge Disassembly, Reassembly, Part 2: 4 단계, 이미지 3개 중 3개
    • Thread the spring into the connected plates.
    • Push the plates into the cartridge against the pressure of the spring.
  5. Atari 5200 Game Cartridge Disassembly, Finishing up: 5 단계, 이미지 3개 중 1개 Atari 5200 Game Cartridge Disassembly, Finishing up: 5 단계, 이미지 3개 중 2개 Atari 5200 Game Cartridge Disassembly, Finishing up: 5 단계, 이미지 3개 중 3개
    • Place the chip in the case.
    • It should "pop" into place.
    • Screw the other side of the case on.
결론
Be sure to test the game, and if freezing still occurs, check the contacts once again.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Zach Petryszyn
회원 가입일: 09/26/14
21 평판
안내서 3개를 작성함
USF Tampa, Team 13-1, Staggers Fall 2014 USF Tampa, Team 13-1, Staggers Fall 2014 회원
USFT-STAGGERS-F14S13G1
5 회원들
안내서 17개를 작성함
2가이드 댓글
I’m curious to see the Atari 2600 cartridge inside but I can’t get my hands on one.
The official meme centre. - 답글
it's not a 2600 cart. the systems have similarities, but they are not pin compatible, nor are they software compatible. the 5200 is its own thing.
Gorilla Sapiens - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 27
전체 시간: 3,597
