주요 콘텐츠로 건너뛰기
Atari 5200 Number Pad Cleaning or Replacement
필요한 것
  1. Atari 5200 Number Pad Cleaning or Replacement, Open the controller: 1 단계, 이미지 1/3 Atari 5200 Number Pad Cleaning or Replacement, Open the controller: 1 단계, 이미지 2/3 Atari 5200 Number Pad Cleaning or Replacement, Open the controller: 1 단계, 이미지 3/3
    • Turn the controller over.
    • Remove the three 6mm screws from the back.
    • Carefully slide and pull the two parts of the controller shell apart, exposing the innards.
    • Do not move the joystick when reassembling. This will break your alignment. The less the joystick is moved, the easier it will be to realign the joystick.
  2. Atari 5200 Number Pad Cleaning or Replacement, Cleaning/Reseating (number pad front and back): 2 단계, 이미지 1/3 Atari 5200 Number Pad Cleaning or Replacement, Cleaning/Reseating (number pad front and back): 2 단계, 이미지 2/3 Atari 5200 Number Pad Cleaning or Replacement, Cleaning/Reseating (number pad front and back): 2 단계, 이미지 3/3
    • Take out the rubber button module of the number pad.
    • Blow out dust on the number pad sensors with compressed air.
    • Wipe the sensors clean with a cloth dabbed with alcohol.
  3. Atari 5200 Number Pad Cleaning or Replacement, Reassembly Part 1: 3 단계, 이미지 1/2 Atari 5200 Number Pad Cleaning or Replacement, Reassembly Part 1: 3 단계, 이미지 2/2
    • Use a spudger to remove the top frame.
    • Take off the plate.
    • Remove the rubber buttons.
  4. Atari 5200 Number Pad Cleaning or Replacement, Reassembly Part 2: 4 단계, 이미지 1/2 Atari 5200 Number Pad Cleaning or Replacement, Reassembly Part 2: 4 단계, 이미지 2/2
    • Pull the circuit strip through the new space.
    • Realign the top and bottom of the controller.
  5. Atari 5200 Number Pad Cleaning or Replacement, Reassembly Part 3: 5 단계, 이미지 1/3 Atari 5200 Number Pad Cleaning or Replacement, Reassembly Part 3: 5 단계, 이미지 2/3 Atari 5200 Number Pad Cleaning or Replacement, Reassembly Part 3: 5 단계, 이미지 3/3
    • Return the buttons to the top of the controller.
    • Snap the frame back into place.
    • Screw the screws back into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alan Abelson
회원 가입일: 09/26/14
233 평판
안내서 5개 작성하였습니다
USF Tampa, Team 13-1, Staggers Fall 2014 USF Tampa, Team 13-1, Staggers Fall 2014 회원
USFT-STAGGERS-F14S13G1
5 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 601
