주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Atari Flashback 2 Console Power Button Replacement
필요한 것
  1. Atari Flashback 2 Console Power Button Replacement, Console Power Button: 1 단계, 이미지 3개 중 1개 Atari Flashback 2 Console Power Button Replacement, Console Power Button: 1 단계, 이미지 3개 중 2개 Atari Flashback 2 Console Power Button Replacement, Console Power Button: 1 단계, 이미지 3개 중 3개
    • Using the screwdriver and PH1 bit, unscrew the five 10.0 mm screws.
    • One is under the main sticker in the middle of the console.
  2. Atari Flashback 2 Console Power Button Replacement: 2 단계, 이미지 3개 중 1개 Atari Flashback 2 Console Power Button Replacement: 2 단계, 이미지 3개 중 2개 Atari Flashback 2 Console Power Button Replacement: 2 단계, 이미지 3개 중 3개
    • Use a PH1 screwdriver to unscrew the two 9.0 mm screws on the circuit board that corresponds to the red power button.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
    • A spring may pop out.
결론
작성자
4다른 기여자 명과 함께
Faith Julian
회원 가입일: 09/18/18
205 평판
안내서 2개를 작성함
Washington State, Team S1-G2, Hope Fall 2018 Washington State, Team S1-G2, Hope Fall 2018 회원
WSU-HOPE-F18S1G2
4 회원들
안내서 11개를 작성함
1가이드 댓글
Hello. I just bought a used atari flashback 2 and when I turn it on it seems that the power button is a little tricky. I wiggle the button in and out and half way etc. then sometimes I can get it to turn on. Once on, the video 'pulses' on and off and a pulsing sound is noticeable. Is it just a faulty power button or is it something worse like a power regulator. I've taken it apart and all seems to be ok looking ie. no burnt fuses etc.  Can you help?  ~Brad Beachin~
bradbeachin - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 24
지난 30일: 100
전체 시간: 1,335
