주요 콘텐츠로 건너뛰기
Atari Flashback 2 Joystick Replacement
필요한 것
  1. Atari Flashback 2 Joystick Replacement, Joystick: 1 단계, 이미지 1/3 Atari Flashback 2 Joystick Replacement, Joystick: 1 단계, 이미지 2/3 Atari Flashback 2 Joystick Replacement, Joystick: 1 단계, 이미지 3/3
    • Using the screwdriver and the PH1 bit, unscrew the four 10.0 mm screws on the bottom of the joystick.
    • Remove the bottom panel from the joystick.
  2. Atari Flashback 2 Joystick Replacement: 2 단계, 이미지 1/2 Atari Flashback 2 Joystick Replacement: 2 단계, 이미지 2/2
    • Use the screwdriver with the PH1 bit to remove the one 10.0 mm screw on the circuit board.
    • Remove the circuit board.
  3. Atari Flashback 2 Joystick Replacement: 3 단계, 이미지 1/2 Atari Flashback 2 Joystick Replacement: 3 단계, 이미지 2/2
    • Remove the rubber pad from the joystick.
  4. Atari Flashback 2 Joystick Replacement: 4 단계, 이미지 1/2 Atari Flashback 2 Joystick Replacement: 4 단계, 이미지 2/2
    • Using a plastic opening tool, poke into the six notches around the bottom of the joystick housing.
    • The joystick's rubber boot will come loose, but stay in place.
  5. Atari Flashback 2 Joystick Replacement: 5 단계, 이미지 1/2 Atari Flashback 2 Joystick Replacement: 5 단계, 이미지 2/2
    • The joystick will now unscrew (counter-clockwise) and you can disassemble the top of the controller into these four parts.
결론
Faith Julian
회원 가입일: 09/18/18
205 평판
안내서 2개 작성하였습니다
Washington State, Team S1-G2, Hope Fall 2018 Washington State, Team S1-G2, Hope Fall 2018 회원
WSU-HOPE-F18S1G2
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 1,470
