이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Using the screwdriver and the PH1 bit, unscrew the four 10.0 mm screws on the bottom of the joystick.
Remove the bottom panel from the joystick.
Use the screwdriver with the PH1 bit to remove the one 10.0 mm screw on the circuit board.
Remove the circuit board.
Using a plastic opening tool, poke into the six notches around the bottom of the joystick housing.
The joystick will now unscrew (counter-clockwise) and you can disassemble the top of the controller into these four parts.
