주요 콘텐츠로 건너뛰기
Atari Flashback 2 Reset and Select Button Replacement
필요한 것
  1. Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: 1 단계, 이미지 3개 중 1개 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: 1 단계, 이미지 3개 중 2개 Atari Flashback 2 Reset and Select Button Replacement, Reset or Select Button: 1 단계, 이미지 3개 중 3개
    • Using the screwdriver and the PH1 bit, unscrew the five 10.0 mm screws on the bottom of the console.
    • One screw is under the main sticker in the middle of the console.
  2. Atari Flashback 2 Reset and Select Button Replacement: 2 단계, 이미지 3개 중 1개 Atari Flashback 2 Reset and Select Button Replacement: 2 단계, 이미지 3개 중 2개 Atari Flashback 2 Reset and Select Button Replacement: 2 단계, 이미지 3개 중 3개
    • Unscrew the six 9.0 mm Phillips #1 screws on the brown circuit board that correspond to the reset and select buttons.
    • Remove gently. The circuit board is connected by wire to the console. Removing the cable from the console case may allow more slack.
결론
작성자
3다른 기여자 명과 함께
Gabriel Robinson
회원 가입일: 09/17/18
85 평판
안내서 1개를 작성함
Washington State, Team S1-G2, Hope Fall 2018 Washington State, Team S1-G2, Hope Fall 2018 회원
WSU-HOPE-F18S1G2
4 회원들
안내서 11개를 작성함
댓글 2개
Good night! I have a flashback2 atari which burst the capacitor EC1, could you help me with its value? Thank you!
pradose - 답글
Hi pradose! We no longer have the device so it will not be possible for our team to walk you through anything beyond the guides we posted.
Daniel Hoffman - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 23
전체 시간: 888
