메인 콘텐츠로 스킵하기
소개
This repair guide will help you with the following:
  • install the right headphone cable
  • fix sound in right ear
  1. Remove the ear pads by peeling them away from the grill.
    • Remove the ear pads by peeling them away from the grill.
  2. Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Remove the speaker from the grill by pulling it out.
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  5. Remove the wires by de-soldering both the red and yellow wires using the soldering iron and desoldering wick. If you need assistance, reference How To Solder and Desolder Connections. The areas where you soldered will be hot so let the soldered joints cool for before handling again.
    • Remove the wires by de-soldering both the red and yellow wires using the soldering iron and desoldering wick. If you need assistance, reference How To Solder and Desolder Connections.
    • The areas where you soldered will be hot so let the soldered joints cool for before handling again.
  6. Connect the the new red and yellow wires by re-soldering the wires using the soldering iron. If you need assistance, reference How To Solder and Desolder Connections. The areas where you soldered will be hot so let the soldered joints cool for before handling again.
    • Connect the the new red and yellow wires by re-soldering the wires using the soldering iron. If you need assistance, reference How To Solder and Desolder Connections.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Melanie Reis
회원 가입일: 2013년 01월 11일
121 평판
안내서 5개 작성하였습니다
Cal Poly, Team 17-19, Forte Winter 2013 Cal Poly, Team 17-19, Forte Winter 2013 회원
CPSU-FORTE-W13S17G19
6 회원들
안내서 6개 작성하였습니다
Where can i buy a replacement cable? Cant seem to find it anywhere.
Stefan Rasmussen - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 47
전체 시간: 2,849
