주요 콘텐츠로 건너뛰기
Audio Technica ATH-M50 Ear pads Replacement
  1. Audio Technica ATH-M50 Ear pads Replacement, Preparing Ear pads for removal: 1 단계, 이미지 1/1
    • Unfold the headphones and lay down flat with the pads facing up
    • Once facing up ,tuck your fingers under the edge of the inside of the ear pad and carefully pull up until the ear pad starts to come off
  2. Audio Technica ATH-M50 Ear pads Replacement, Removing the ear pad: 2 단계, 이미지 1/1
    • After creating a gap continue to lift the ear pad off until fully removed
    • For reinstalling the ear pads use the same techniques for a easy installation
    • On older headphones the foam sponge part of the ear pad can deteriorate,it is recommended that if there is any leftover foam that it is remove to the best of your ability to improve the longevity of the headphone,the drivers are delicate please be careful:-)
    • Congratulations you have now removed your M50’s ear pads:-)
결론
다른 2명이 해당 안내서를 완성하였습니다.
HelloMacOS
회원 가입일: 01/24/22
26,080 평판
안내서 11개 작성하였습니다
Repair is War on Entropy Repair is War on Entropy 회원
Community
26 회원들
안내서 1,185개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 9
30일 전: 52
전체 시간: 1,040
