주요 콘텐츠로 건너뛰기
Audio-Technica AT-LP120-USB Precision 500 mA Regulator Replacement
필요한 것
  1. Audio-Technica AT-LP120-USB Precision 500 mA Regulator Replacement, Precision 500 mA Regulator: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #2 screwdriver to remove the four 2.5 mm screws.
  2. Audio-Technica AT-LP120-USB Precision 500 mA Regulator Replacement: 2 단계, 이미지 1개 중 1개
    • Identify the Precision 500 mA Regulator.
    • If there is RTV Adhesive Glue, slightly pull back and forth on the Precision 500 mA Regulator to loosen the glue and break it free.
  3. Audio-Technica AT-LP120-USB Precision 500 mA Regulator Replacement: 3 단계, 이미지 1개 중 1개
    • Flip the board that was loosened from removing the four screws and go on the opposite side of where the Regulator is located. Desolder the regulator.
    • Remove the faulty regulator.
    • A new regulator will need to be soldered back on.
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Tommy
회원 가입일: 10/22/24
127 평판
안내서 1개를 작성함
Cuesta, Team 20-3, Krynen Fall 2024 Cuesta, Team 20-3, Krynen Fall 2024 회원
CUESTA-KRYNEN-F24S20G3
5 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 10
지난 30일: 42
전체 시간: 258
