주요 콘텐츠로 건너뛰기
Audio-Technica AT-LP60BK-BT Belt Drive Replacement
필요한 것
  1. Audio-Technica AT-LP60BK-BT Belt Drive Replacement, Belt Drive: 1 단계, 이미지 1/2 Audio-Technica AT-LP60BK-BT Belt Drive Replacement, Belt Drive: 1 단계, 이미지 2/2
    • Open the top plastic cover and remove the record and rubber mat.
  2. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: 2 단계, 이미지 1/2 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: 2 단계, 이미지 2/2
    • Find the belt underneath the platter by rotating the platter to the correct place.
    • Remove the belt from the motor pulley.
  3. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: 3 단계, 이미지 1/1
    • Take the platter off by pulling it straight up.
  4. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: 4 단계, 이미지 1/2 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: 4 단계, 이미지 2/2
    • Remove the old belt.
  5. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: 5 단계, 이미지 1/1
    • Turn platter upside down.
  6. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: 6 단계, 이미지 1/3 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: 6 단계, 이미지 2/3 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: 6 단계, 이미지 3/3
    • Place the new belt around the inner lap on the upside-down platter.
    • Make sure the rubber band is flat on the platter, with no flipping.
  7. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: 7 단계, 이미지 1/1
    • Turn the platter around.
    • Grab the belt around with a finger through one of the holes in the platter.
  8. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: 8 단계, 이미지 1/1
    • Put the platter straight down.
  9. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: 9 단계, 이미지 1/1
    • Put the belt around the motor pulley.
  10. Audio-Technica AT-LP60BK-BT Belt Drive Replacement: 10 단계, 이미지 1/3 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: 10 단계, 이미지 2/3 Audio-Technica AT-LP60BK-BT Belt Drive Replacement: 10 단계, 이미지 3/3
    • Test the function by spinning the platter and put the rubber mat into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Zonghao Li
회원 가입일: 01/20/21
208 평판
안내서 1개 작성함
York University, Team S1-G15, Melo-Thaiss Winter 2021 York University, Team S1-G15, Melo-Thaiss Winter 2021 회원
YORK-MELO-THAISS-W21S1G15
1 회원
안내서 1개 작성하였습니다
댓글 한 개
Thank you so much!
Joe - 답글
댓글 쓰기
조회 통계:
24 시간 전: 21
7일 전: 158
30일 전: 751
전체 시간: 9,477
