소개
This guide will deal with how to replace the broken or missing belt drive for Audio-Technica AT-LP60BK-BT Bluetooth Wireless Turntable. The rubber band could cause a malfunction and break after using a long time or under extreme temperatures.
Before using this guide, make sure the size of the new belt is designed specifically for this model to avoid motor overheat problem.
필요한 것
다른 한 분이 해당 안내서를 완성하였습니다.
