주요 콘텐츠로 건너뛰기
Audio-Technica LP60XBT Turntable Gear Replacement
필요한 것
  1. Audio-Technica LP60XBT Turntable Gear Replacement, Gear: 1 단계, 이미지 2개 중 1개 Audio-Technica LP60XBT Turntable Gear Replacement, Gear: 1 단계, 이미지 2개 중 2개
    • Remove the felt pad, and put it to the side.
  2. Audio-Technica LP60XBT Turntable Gear Replacement: 2 단계, 이미지 1개 중 1개
    • Turn the platter so that the brass motor pulley can be seen through one of the two outer holes in the platter.
    • If the drive belt is hooked around the motor pulley, unhook it.
    • When reassembling to device, don't forget to hook the new drive belt to the motor pulley.
  3. Audio-Technica LP60XBT Turntable Gear Replacement: 3 단계, 이미지 2개 중 1개 Audio-Technica LP60XBT Turntable Gear Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the platter by grasping the platter by its two inner holes and lifting it upwards.
    • If the drive belt is unhooked and the tone arm is safely to the side, don’t be afraid to use a small amount of force in lifting the platter if necessary.
  4. Audio-Technica LP60XBT Turntable Gear Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the four screws holding in the gears using a Phillips #0 screwdriver.
  5. Audio-Technica LP60XBT Turntable Gear Replacement: 5 단계, 이미지 3개 중 1개 Audio-Technica LP60XBT Turntable Gear Replacement: 5 단계, 이미지 3개 중 2개 Audio-Technica LP60XBT Turntable Gear Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the large white gear by pulling it upwards.
    • Remove the small white gear and base by pulling them upwards.
  6. Audio-Technica LP60XBT Turntable Gear Replacement: 6 단계, 이미지 1개 중 1개
    • Insert the small replacement gear first, then the large replacement gear second.
    • When replacing the smaller gear and base, be sure to feed the black ground wire through the hole in the base.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Devon Ferreira
회원 가입일: 03/22/21
238 평판
안내서 1개를 작성함
UMass Dartmouth, Team S1-G8, Sinclaire Spring 2021 UMass Dartmouth, Team S1-G8, Sinclaire Spring 2021 회원
UMASSD-SINCLAIRE-S21S1G8
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 12
지난 30일: 61
전체 시간: 2,190
