소개
This guide will show you how to replace the [main] LCD screen on the Audiovox CDM-8900.
Remove screw covers (4 in total) using the spudger.
Note: Because the bottom two screw covers are attached with an adhesive, you will not be able to replace them when you reassemble the phone.
WARNING: Do not detach or tear any wires when completing this step.
Using the spudger, carefully separate the black discs (speaker and microphone) from the inside surface of the phone.
Note: The smaller black disc is glued down, so you may need to use some force to detach it. Both disks will still remain attached via wires.
