이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Wedge one of the plastic opening tools under the phone cover near the hinge.
Insert the second plastic opening tool under the phone cover and slide it around the perimeter.
Detach the phone cover from the phone's base.
Slide out the two metal braces located along the sides of the LCD screen.
Carefully peel back the tape from both sides of the copper frame.
Using the spudger, carefully separate the speaker and microphone from the inside surface of the phone.
With the copper screen lifted up, gently pull out the ribbon connector and lift out the LCD screen.
