소개
The LCD screen is the main display of the Audiovox CDM-8910.
  1. With phone in the flipped-open position, use a spudger to remove the four (4) rubber pads (one shown in red circle) located near the corners of the face with the LCD screen.
    • With phone in the flipped-open position, use a spudger to remove the four (4) rubber pads (one shown in red circle) located near the corners of the face with the LCD screen.
  2. Use a small Phillips head screwdriver to remove the four (4) screws exposed by removed rubber pads.
    • Use a small Phillips head screwdriver to remove the four (4) screws exposed by removed rubber pads.
  3. Use a spudger to pry the front cover off of the phone, gradually working your way around the front face.
    • Use a spudger to pry the front cover off of the phone, gradually working your way around the front face.
  4. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  5. Use a spudger to lift away and remove the metallic frame (in blue).
    • Use a spudger to lift away and remove the metallic frame (in blue).
    • Use the spudger to lift away the two electrical contacts (in red).
    • Use the spudger to lift away the speaker (in yellow).
  6. This is what the rear of the LCD screen should look like before proceeding.  Note all necessary connections are undone.
    • This is what the rear of the LCD screen should look like before proceeding. Note all necessary connections are undone.
  7. Use a spudger to lift away the LCD screen.
    • Use a spudger to lift away the LCD screen.
  8. LCD screen successfully removed!
    • LCD screen successfully removed!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kevin Jafarey
회원 가입일: 2010년 10월 04일
11 평판
안내서 2개 작성하였습니다
Cal Poly, Team 3-24, Regan Fall 2010 Cal Poly, Team 3-24, Regan Fall 2010 회원
CPSU-REGAN-F10S3G24
4 회원들
안내서 12개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 2,773
