주요 콘텐츠로 건너뛰기
Audiovox CDM-8910 Motherboard Replacement
필요한 것
  1. Audiovox CDM-8910 Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Locate the back side of the phone.
    • The battery is the large main compartment (red box).
  2. Audiovox CDM-8910 Motherboard Replacement: 2 단계, 이미지 1/1
    • Use your finger to slide the latch (circled) upwards.
    • While holding the latch up, pull the battery off the phone.
  3. Audiovox CDM-8910 Motherboard Replacement: 3 단계, 이미지 1/1
    • The back of the phone will look like this when the battery is correctly removed.
  4. Audiovox CDM-8910 Motherboard Replacement, Rear Case: 4 단계, 이미지 1/1
    • Peel the rubber indicated toward the top of the phone
  5. Audiovox CDM-8910 Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the screw that sits underneath the rubber covering.
  6. Audiovox CDM-8910 Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the five (5) total screws using a Philips head screwdriver.
  7. Audiovox CDM-8910 Motherboard Replacement: 7 단계, 이미지 1/1
    • Use spudger and insert it towards the bottom of the phone as pictured.
    • Carefully working yourself around the phone with the spudger, pry it open. This may require a bit of force.
    • The volume control button will be loose, so make sure to take it out once the rear case is fully removed.
  8. Audiovox CDM-8910 Motherboard Replacement: 8 단계, 이미지 1/1
    • The back case should now be completely removed and the motherboard will be visible.
  9. Audiovox CDM-8910 Motherboard Replacement, Motherboard: 9 단계, 이미지 1/3 Audiovox CDM-8910 Motherboard Replacement, Motherboard: 9 단계, 이미지 2/3 Audiovox CDM-8910 Motherboard Replacement, Motherboard: 9 단계, 이미지 3/3
    • Disconnect the gold connection patch
    • Use a spudger or finger to disconnect the piece.
  10. Audiovox CDM-8910 Motherboard Replacement: 10 단계, 이미지 1/1
    • Using a spudger, lift the motherboard out of the phone case as pictured.
  11. Audiovox CDM-8910 Motherboard Replacement: 11 단계, 이미지 1/1
    • The motherboard should now be completely removed from the phone.
결론
Sean Green
회원 가입일: 10/04/10
29 평판
안내서 2개 작성하였습니다
Cal Poly, Team 3-24, Regan Fall 2010 Cal Poly, Team 3-24, Regan Fall 2010 회원
CPSU-REGAN-F10S3G24
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
Where on this phone’s motherboard is the memory card located? I’d like to try and remove mine to download the data from it.
Ernie Freeman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 16
전체 시간: 2,227
