주요 콘텐츠로 건너뛰기
Audiovox CR8030iE5 Docking Port Replacement
필요한 것
  1. Audiovox CR8030iE5 Docking Port Replacement, Top-Casing: 1 단계, 이미지 1/1
    • Turn the device upside down.
    • Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
  2. Audiovox CR8030iE5 Docking Port Replacement: 2 단계, 이미지 1/1
    • Remove the four screws from the base using a Phillips #1 screwdriver.
  3. Audiovox CR8030iE5 Docking Port Replacement: 3 단계, 이미지 1/1
    • Turn the device right-side up.
    • Gently pull the top panel off of the device.
  4. Audiovox CR8030iE5 Docking Port Replacement: 4 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
  5. Audiovox CR8030iE5 Docking Port Replacement: 5 단계, 이미지 1/1
    • Pull back the board gently to avoid disconnecting the attached wires.
    • This allows you to view the soldered connections on the other side, and the internal components.
  6. Audiovox CR8030iE5 Docking Port Replacement, Docking Port: 6 단계, 이미지 1/1
    • One by one, de-solder the line of nine wires attached to the docking port board. After pulling out the wires, save them. This is done so that you can solder them into the new docking port board.
    • If you don't know how to solder, check out How To Solder and Desolder Connections.
    • Soldering irons are extremely hot and can burn you if you touch them!
    • If you hold the soldering iron tip at the same spot for too long, it can strip the metal from the plastic board. You may not be able to solder wire to that point again.
  7. Audiovox CR8030iE5 Docking Port Replacement: 7 단계, 이미지 1/1
    • Carefully insert the wires into the designated holes on the new docking port board and solder them into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nab Sengupta
회원 가입일: 04/18/13
55 평판
안내서 4개 작성하였습니다
Cal Poly, Team 10-39, Amido Spring 2013 Cal Poly, Team 10-39, Amido Spring 2013 회원
CPSU-AMIDO-S13S10G39
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 345
