소개
If the speakers aren't working... install new ones! This guide shows you how to change out old speakers that may not be working right.
부품
부품은 필요하지 않습니다.
Begin by applying constant pressure to the base of your Audiovox while holding the plastic casing. Do this until the plastic casing is completely removed.
Slide a plastic opening tool along the rim of the faulty speaker where it meets the plastic casing.
다른 3명이 해당 안내서를 완성하였습니다.
