소개
So the speaker in your Audiovox CR8030iE5 has not been producing any audio or has not been sounding good at all and you think you have to go buy a new one. Well, hold on! We have a simple fix for that.
Fortunately, if your audio does not work/sounds bad chances are you have a speaker going out and it needs to be replaced. We all know how important it is to hear quality audio.
With the help of this guide, Phillips Screwdriver's, and a plastic opening tool this can make the replacement process feel like a breeze!
Remember! Each speaker has a powerful magnet, so be sure to be very cautious of other metal surroundings.
필요한 것
Turn the device upside down.
Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
Slide a plastic opening tool along the rim of the faulty speaker where it meets the plastic casing.
다른 3명이 해당 안내서를 완성하였습니다.
