주요 콘텐츠로 건너뛰기
Audiovox CR8030iE5 Top-Casing Replacement
필요한 것
  1. Audiovox CR8030iE5 Top-Casing Replacement, Top-Casing: 1 단계, 이미지 1/1
    • Turn the device upside down.
    • Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
  2. Audiovox CR8030iE5 Top-Casing Replacement: 2 단계, 이미지 1/1
    • Remove the four screws from the base using a Phillips #1 screwdriver.
  3. Audiovox CR8030iE5 Top-Casing Replacement: 3 단계, 이미지 1/1
    • Turn the device right-side up.
    • Gently pull the top panel off of the device.
  4. Audiovox CR8030iE5 Top-Casing Replacement: 4 단계, 이미지 1/1
    • Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
  5. Audiovox CR8030iE5 Top-Casing Replacement: 5 단계, 이미지 1/1
    • Pull back the board gently to avoid disconnecting the attached wires.
    • This allows you to view the soldered connections on the other side, and the internal components.
결론
Savannah Smith
회원 가입일: 04/18/13
51 평판
안내서 2개 작성하였습니다
Cal Poly, Team 10-39, Amido Spring 2013 Cal Poly, Team 10-39, Amido Spring 2013 회원
CPSU-AMIDO-S13S10G39
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 332
