주요 콘텐츠로 건너뛰기
Audiovox T752 Camera Replacement
필요한 것
  1. Audiovox T752 Camera Replacement, Back Panel: 1 단계, 이미지 1/3 Audiovox T752 Camera Replacement, Back Panel: 1 단계, 이미지 2/3 Audiovox T752 Camera Replacement, Back Panel: 1 단계, 이미지 3/3
    • Find a good spot to fit the pry bar between the back cover and tablet. Slowly drag the pry bar along the sides of the cover.
    • NOTE: some force will need to be used to remove the cover. Avoid excessive force.
  2. Audiovox T752 Camera Replacement, Camera: 2 단계, 이미지 1/2 Audiovox T752 Camera Replacement, Camera: 2 단계, 이미지 2/2
    • Remove the pink and aluminum protective cover. Be sure to also remove any tape holding it in place.
  3. Audiovox T752 Camera Replacement: 3 단계, 이미지 1/2 Audiovox T752 Camera Replacement: 3 단계, 이미지 2/2
    • Remove the orange camera strip from the motherboard.
    • Insert new camera strip and place the pink and aluminum protective cover back in the device.
    • NOTE: camera strip may be loose when reconnected. Use of electrical tape may be required.
결론
Logan
회원 가입일: 01/28/15
391 평판
안내서 3개 작성하였습니다
Penn State, Team 2-42, Kaschak Winter 2015 Penn State, Team 2-42, Kaschak Winter 2015 회원
PSU-KASCHAK-W15S2G42
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 225
