주요 콘텐츠로 건너뛰기
Audiovox Tri-mode CDM-9000 Battery Replacement
  1. Audiovox Tri-mode CDM-9000 Battery Replacement, Replacing the Battery: 1 단계, 이미지 1/3 Audiovox Tri-mode CDM-9000 Battery Replacement, Replacing the Battery: 1 단계, 이미지 2/3 Audiovox Tri-mode CDM-9000 Battery Replacement, Replacing the Battery: 1 단계, 이미지 3/3
    • Flip your phone over so the screen is facing down.
    • About half way down there is a small button with a few groves. Push this button in an upward fashion. This will release the battery from the back of the cell phone.
  2. Audiovox Tri-mode CDM-9000 Battery Replacement, Remove Battery: 2 단계, 이미지 1/2 Audiovox Tri-mode CDM-9000 Battery Replacement, Remove Battery: 2 단계, 이미지 2/2
    • Once the back piece is released, simply lift the battery up and away from the phone.
    • Replace the battery by placing the bottom part of the battery in first and push down. You will hear a loud click sound when the battery is secure.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Summer Sines
회원 가입일: 09/27/14
406 평판
안내서 3개 작성하였습니다
USF Sarasota-Manatee, Team 1-3, Stewart Fall 2014 USF Sarasota-Manatee, Team 1-3, Stewart Fall 2014 회원
USFSM-STEWART-F14S1G3
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 343
