주요 콘텐츠로 건너뛰기
Audiovox Tri-mode CDM-9000 Keypad Replacement
필요한 것
  1. Audiovox Tri-mode CDM-9000 Keypad Replacement, Keypad: 1 단계, 이미지 1/3 Audiovox Tri-mode CDM-9000 Keypad Replacement, Keypad: 1 단계, 이미지 2/3 Audiovox Tri-mode CDM-9000 Keypad Replacement, Keypad: 1 단계, 이미지 3/3
    • Flip your phone over so the screen is facing down.
    • About half way down there is a small button with a few groves. Push this button in an upward fashion. This will release the battery from the back of the cell phone.
  2. Audiovox Tri-mode CDM-9000 Keypad Replacement: 2 단계, 이미지 1/3 Audiovox Tri-mode CDM-9000 Keypad Replacement: 2 단계, 이미지 2/3 Audiovox Tri-mode CDM-9000 Keypad Replacement: 2 단계, 이미지 3/3
    • Once the battery has been removed, you will need a small Phillips 60 mm screwdriver. Remove the two 1.2mm Phillips #1 screws on the back of the phone.
    • Use a spudger tool to pry apart the phone. It may be a little difficult to pry open. Use the flat part of the spudger tool and go all around the phone. It will come apart.
  3. Audiovox Tri-mode CDM-9000 Keypad Replacement: 3 단계, 이미지 1/3 Audiovox Tri-mode CDM-9000 Keypad Replacement: 3 단계, 이미지 2/3 Audiovox Tri-mode CDM-9000 Keypad Replacement: 3 단계, 이미지 3/3
    • Once you have the phone apart simply remove the key pad and replace it with the new one.
    • Don't forget to put the screws back in. Place the battery back on the phone.
    • Push the two parts of the phone back together. You will here a loud click when the phone is back together.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Summer Sines
회원 가입일: 09/27/14
406 평판
안내서 3개 작성하였습니다
USF Sarasota-Manatee, Team 1-3, Stewart Fall 2014 USF Sarasota-Manatee, Team 1-3, Stewart Fall 2014 회원
USFSM-STEWART-F14S1G3
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 219
