주요 콘텐츠로 건너뛰기
August Smart Lock Gear Replacement
필요한 것
  1. August Smart Lock Gear Replacement, Gear: 1 단계, 이미지 3개 중 1개 August Smart Lock Gear Replacement, Gear: 1 단계, 이미지 3개 중 2개 August Smart Lock Gear Replacement, Gear: 1 단계, 이미지 3개 중 3개
    • Flip the device over so the metal plate is facing you.
    • Undo the latches on the side to remove the metal plate.
    • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
    • To unscrew all of the screws, you will need to close the latches again.
    • Do not pull the cover apart too far as the speaker is in the cover and connected to the motherboard.
  2. August Smart Lock Gear Replacement: 2 단계, 이미지 3개 중 1개 August Smart Lock Gear Replacement: 2 단계, 이미지 3개 중 2개 August Smart Lock Gear Replacement: 2 단계, 이미지 3개 중 3개
    • Lift the cover off the device and set to the side.
    • The cover contains the speaker which is connected to the motherboard so do not pull to far apart.
    • Remove the gears as shown.
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
William Fink
회원 가입일: 09/26/17
814 평판
안내서 3개를 작성함
USF Tampa, Team S11-G6, Passmore Fall 2017 USF Tampa, Team S11-G6, Passmore Fall 2017 회원
USFT-PASSMORE-F17S11G6
4 회원들
안내서 3개를 작성함
8가이드 댓글
The tittle of this topic is: August Smart Lock Gear Replacement, but I don't see any spare part replacement at all!
Walter Quintero - 답글
Any tips on where to get replacement gears?
Byron H - 답글
The gear connecting the motor is cracked. I'd also like to know where to get parts other than buying another broken August lock that's broken in another way.
Robert F. Jobin Jr. - 답글
Robert, where you able to find this replacement gear? Mine broke this week and having a hard time to find the part. Thanks
Luiz Cavalcante -
Anyone find gear replacements? The. Am on the motor shaft cracked on mine
pennytrotz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 51
전체 시간: 13,539
