주요 콘텐츠로 건너뛰기
August Smart Lock Speaker Replacement
필요한 것
  1. August Smart Lock Speaker Replacement, Speaker: 1 단계, 이미지 3개 중 1개 August Smart Lock Speaker Replacement, Speaker: 1 단계, 이미지 3개 중 2개 August Smart Lock Speaker Replacement, Speaker: 1 단계, 이미지 3개 중 3개
    • Flip the device so the back cover is facing you.
    • Undo the latches on both sides to remove the metal cover.
    • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
    • To unscrew all of the screws, you will need to close the latches again.
    • Do not pull the cover apart too far as the speaker is in the cover and connected to the motherboard.
  2. August Smart Lock Speaker Replacement: 2 단계, 이미지 3개 중 1개 August Smart Lock Speaker Replacement: 2 단계, 이미지 3개 중 2개 August Smart Lock Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Use the metal spudger to pry the plug off of the motherboard.
    • The plug can be dislodged when prying it from the side.
  3. August Smart Lock Speaker Replacement: 3 단계, 이미지 3개 중 1개 August Smart Lock Speaker Replacement: 3 단계, 이미지 3개 중 2개 August Smart Lock Speaker Replacement: 3 단계, 이미지 3개 중 3개
    • Warm up the iOpener.
    • Do not place the iOpener in microwave for more than 30 seconds.
    • Place the iOpener heating pad over the speaker and let sit for a few moments.
    • Using the metal spudger, pry some of the glue off the hinges holding the speaker in place.
  4. August Smart Lock Speaker Replacement: 4 단계, 이미지 2개 중 1개 August Smart Lock Speaker Replacement: 4 단계, 이미지 2개 중 2개
    • Once the speaker looks mobile, flip the cover over and push below the speaker to pop it out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
William Fink
회원 가입일: 09/26/17
814 평판
안내서 3개를 작성함
USF Tampa, Team S11-G6, Passmore Fall 2017 USF Tampa, Team S11-G6, Passmore Fall 2017 회원
USFT-PASSMORE-F17S11G6
4 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 13
전체 시간: 1,704
