주요 콘텐츠로 건너뛰기
Austauschen der Rückabdeckung des Sony Xperia Z3 Compact
필요한 것
  1. Austauschen der Rückabdeckung des Sony Xperia Z3 Compact, Kleber des Gehäuses erhitzen: 1 단계, 이미지 1/1
    • Erhitze entlang den Kanten der Rückabdeckung, um den Kleber aufzuweichen.
    • Empfohlene Temperatur: 120-150°C für 60 Sekunden.
  2. Austauschen der Rückabdeckung des Sony Xperia Z3 Compact: 2 단계, 이미지 1/1
    • Setze den Saugnapf auf und ziehe daran, während du das Smartphone festhältst, um einen Spalt zu öffnen.
    • Stecke ein Plektrum in die Lücke, um den Kleber unter dem Rückgehäuse zu lösen.
  3. Austauschen der Rückabdeckung des Sony Xperia Z3 Compact: 3 단계, 이미지 1/1
    • Nimm die Rückwand ab.
    • Sei Vorsichtig, die Rückwand ist zerbrechlich. Mit dem Tragen einer Schutzbrille kann man die Augen vor Glassplittern schützen.
    • Beim Wiederzusammenbau das Telefon über Nacht mit etwas beschweren, um eine bessere Haftung des neuen Klebestreifens zu garantieren.
결론
Um dein Gerät wieder zusammenzubauen, folge den Schritten in umgekehrter Reihenfolge.
다른 38명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
en de
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Sophia
회원 가입일: 03/25/14
43,810 평판
안내서 62개 작성하였습니다
댓글 8개
I think this guide shows how to open a phone that's already been opened. I have seen another that showed all the glue between the battery and the back cover that can take a lot of effort to remove, plus once done then (if it was before) it will not longer be waterproof.
Paul - 답글
I replaced battery cover and I heat up new one. It looks like it become waterproof again.
Vladimir Gorshunov -
It will no longer be waterproof, unless you are using the exact same quality and amount of adhesive as the original one, and you press the back glass to the phone as hard as it was before.
If not, then it is hardly waterproof.
Thingalong - 답글
I used a domestic hair dryer for about 2 minutes to heat the back of the phone which softened the glue enough for the rear panel to be removed. A layer of glue remained around the frame. The replacement part also had a gummed edge and stuck quite firmly without needing any pressure.
I reheated the rear to soften the new glue and then held the phone in two small clamps gently but firmly until the phone had cooled (overnight as it was convenient).
The phone is waterproof.
IanW - 답글
Do not forget to clean the phone (remove the rest of the glue sticking on the phone). It will fit better with no old glue.
duesseldorfhahn - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 46,232
