주요 콘텐츠로 건너뛰기
Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly
필요한 것
  1. Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly, Taking Main cover off: 1 단계, 이미지 1/2 Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly, Taking Main cover off: 1 단계, 이미지 2/2
    • Using a T10 screwdriver, remove the eight screws located on the rear panel of the device (4 towards the bottom, and 4 towards the top).
  2. Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: 2 단계, 이미지 1/2 Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: 2 단계, 이미지 2/2
    • Unscrew one PH2 screw.
    • Use a spudger or a thin curved tool such as a dental pick to remove the bean hopper of the burr grinder.
    • Remove the grind selector by pulling the dial directly away from the machine which will remove it from the housing.
  3. Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: 3 단계, 이미지 1/2 Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: 3 단계, 이미지 2/2
    • The Hex screw must be unscrewed in the clockwise direction. Failure to do so could result in damage of the grinding mechanism.
    • Unscrew the one 4mm Hex in a clockwise fashion and remove the black plastic cover over the burrset.
    • Remove the black plastic cover over the burr set.
    • The burr set should not be completely visible.
  4. Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: 4 단계, 이미지 1/2 Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: 4 단계, 이미지 2/2
    • Unscrew the three PH2 screws.
    • Slide the top panel backwards to remove it.
  5. Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: 5 단계, 이미지 1/3 Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: 5 단계, 이미지 2/3 Automatic Coffee Machine Cecotec Power Matic-Ccino 7000 or Rooma RM-A7 Disassembly: 5 단계, 이미지 3/3
    • Now you should have access to the internal components of the appliance.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Egas
회원 가입일: 09/20/10
181 평판
안내서 1개 작성함
Zi repair Zi repair 회원
Business
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 24
30일 전: 177
전체 시간: 3,278
