주요 콘텐츠로 건너뛰기
Automatic Tommy 20 Ammo Drum Replacement
필요한 것
  1. Automatic Tommy 20 Ammo Drum Replacement, Splitting the Gun into Two Halves: 1 단계, 이미지 1/2 Automatic Tommy 20 Ammo Drum Replacement, Splitting the Gun into Two Halves: 1 단계, 이미지 2/2
    • Locate the orange slider on the front side of the gun.
    • Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
  2. Automatic Tommy 20 Ammo Drum Replacement: 2 단계, 이미지 1/3 Automatic Tommy 20 Ammo Drum Replacement: 2 단계, 이미지 2/3 Automatic Tommy 20 Ammo Drum Replacement: 2 단계, 이미지 3/3
    • Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver.
    • Remove all parts within the chamber to be able to completely detach the nose of the gun.
    • Be careful to keep track of all the components for reassembly.
  3. Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: 3 단계, 이미지 1/3 Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: 3 단계, 이미지 2/3 Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: 3 단계, 이미지 3/3
    • Remove the 1/16 in. screws using a Phillips #00 Screwdriver as indicated in the photo on the left.
    • Remove the 1 mm screw on the battery lid using a Philips #1 Screwdriver as indicated in the photo on the left.
  4. Automatic Tommy 20 Ammo Drum Replacement: 4 단계, 이미지 1/1
    • Carefully spread apart the two halves of the gun, and lift out the ammo drum.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Moira Foster
회원 가입일: 10/09/14
419 평판
안내서 3개 작성하였습니다
Cal Poly, Team 6-22, Maness Fall 2014 Cal Poly, Team 6-22, Maness Fall 2014 회원
CPSU-MANESS-F14S6G22
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 789
