주요 콘텐츠로 건너뛰기
Autosampler Battery Replacement & Voltage Check (For Old & New Versions)
필요한 것
  1. Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Disconnect the batteries completely: 1 단계, 이미지 1/3 Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Disconnect the batteries completely: 1 단계, 이미지 2/3 Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Disconnect the batteries completely: 1 단계, 이미지 3/3
    • 1. Disconnect the plug to the solar panel (yellow circle).
    • Then, grabbing the green connector and pull the battery connector from the solar charge controller (blue arrow).
    • This will be done inside the node. It was removed from the node to make it easier to see for the tutorial.
    • 2. Disconnect the plugs for the autosampler battery.
    • 3. Disconnect the connector that plugs into the battery port of the sampler.
    • If disconnect battery before solar panel, this can damage the solar charger!
  2. Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Checking battery voltages: 2 단계, 이미지 1/3 Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Checking battery voltages: 2 단계, 이미지 2/3 Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Checking battery voltages: 2 단계, 이미지 3/3
    • 4. Make sure multimeter is measuring in DC current (red boxes).
    • Make sure multimeter is measuring in Volts (blue box).
    • 5. Check the voltage of the lead acid autosampler battery. Fully charged lead acid battery should be around 13-14 V.
    • Remember: Red to red and black to black!
    • 6. Check the voltage of the lithium ion node battery. Fully charged lithium ion battery should around 4 V.
  3. Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Reconnect the batteries: 3 단계, 이미지 1/3 Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Reconnect the batteries: 3 단계, 이미지 2/3 Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Reconnect the batteries: 3 단계, 이미지 3/3
    • 7. First reconnect the autosampler battery (black box).
    • 8. Then reconnect lithium ion battery in the node (blue box).
    • Remember to plug in the other connector into the autosampler.
    • 9. Secure solar charge controller to the side of the enclosure using velcro (red box).
    • Then plug in the solar panel last (orange box).
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Brooke Mason
회원 가입일: 05/29/19
2,928 평판
안내서 17개 작성하였습니다
Open-Storm Open-Storm 회원
Community
14 회원들
안내서 24개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 152
