주요 콘텐츠로 건너뛰기
Autosampler Configuration for Node Control (For Old & New Versions)
필요한 것
  1. Autosampler Configuration for Node Control  (For Old & New Versions), Starting the configuration process.: 1 단계, 이미지 1/3 Autosampler Configuration for Node Control  (For Old & New Versions), Starting the configuration process.: 1 단계, 이미지 2/3 Autosampler Configuration for Node Control  (For Old & New Versions), Starting the configuration process.: 1 단계, 이미지 3/3
    • 1. Turn on the autosampler. Screen will read "...STANDBY..."
    • 2. Press "ENTER/PROGRAM" button. Use arrows to highlight "CONFIGURE". Press "ENTER/PROGRAM" button
    • This will allow you to use the arrows to shuffle through the different configuration options. To select the one you want, press the "ENTER/PROGRAM" button.
    • 3. Use arrows to find "EVENT MARK". Press the "ENTER/PROGRAM" button.
  2. Autosampler Configuration for Node Control  (For Old & New Versions), Configuring "event mark".: 2 단계, 이미지 1/3 Autosampler Configuration for Node Control  (For Old & New Versions), Configuring "event mark".: 2 단계, 이미지 2/3 Autosampler Configuration for Node Control  (For Old & New Versions), Configuring "event mark".: 2 단계, 이미지 3/3
    • 4. Use arrow to select "CONTINUOUS SIGNAL". Press "ENTER/PROGRAM" button.
    • 5. Use arrow to select "PUMP CYCLE". Press "ENTER/PROGRAM" button.
    • It is critical this setting is configured in order for the sensor node to operate the autosampler!
    • 6. Use arrows to find "EXIT CONFIGURATION." Press "ENTER/PROGRAM" button. This will bring up the screen "...STANDBY...
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Brooke Mason
회원 가입일: 05/29/19
2,928 평판
안내서 17개 작성하였습니다
Open-Storm Open-Storm 회원
Community
14 회원들
안내서 24개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 89
