주요 콘텐츠로 건너뛰기
Autosampler Node Troubleshooting (For New & Old Versions)
  1. Autosampler Node Troubleshooting (For New & Old Versions), Confirm node is sending readings.: 1 단계, 이미지 2개 중 1개 Autosampler Node Troubleshooting (For New & Old Versions), Confirm node is sending readings.: 1 단계, 이미지 2개 중 2개
    • 1. Check the farm-n-storm website for that node to make sure node has sent a reading in the last hour.
    • 2. Contact the Real-Time Water Systems Lab to update the sampling frequency to every 5 minutes to make testing easier.
  2. Autosampler Node Troubleshooting (For New & Old Versions), Disconnect batteries completely.: 2 단계, 이미지 3개 중 1개 Autosampler Node Troubleshooting (For New & Old Versions), Disconnect batteries completely.: 2 단계, 이미지 3개 중 2개 Autosampler Node Troubleshooting (For New & Old Versions), Disconnect batteries completely.: 2 단계, 이미지 3개 중 3개
    • 3. Disconnect the plug to the solar panel.
    • Then, grabbing the green connector, pull the battery connector from the solar charge controller.
    • 4. Disconnect the plugs for the autosampler battery.
    • 5. Disconnect the connector that plugs into the battery port of the sampler.
    • If disconnect battery before solar panel, this can damage the solar charger!
  3. Autosampler Node Troubleshooting (For New & Old Versions), Check autosampler: 3 단계, 이미지 1개 중 1개
    • 6. Confirm the autosampler is configured correctly. See this tutorial for more details.
    • Confirm the autosampler is programming correctly. See this tutorial for more details.
  4. Autosampler Node Troubleshooting (For New & Old Versions), Check autosampler: 4 단계, 이미지 1개 중 1개
    • Now we will trigger a sample from the autosampler to confirm the sampling works.
    • 7. Press the "MANUAL SAMPLE" button and then "ENTER/PROGRAM".
    • Confirm the autosampler stars.
  5. Autosampler Node Troubleshooting (For New & Old Versions), Trigger autosampler with 6-pin connector: 5 단계, 이미지 3개 중 1개 Autosampler Node Troubleshooting (For New & Old Versions), Trigger autosampler with 6-pin connector: 5 단계, 이미지 3개 중 2개 Autosampler Node Troubleshooting (For New & Old Versions), Trigger autosampler with 6-pin connector: 5 단계, 이미지 3개 중 3개
    • Get the modified 6-pin connector to test the autosampler
    • Connect the 12V battery to the autosampler
    • Push the On button and then Start Sampling
  6. Autosampler Node Troubleshooting (For New & Old Versions), Trigger autosampler with 6-pin connector: 6 단계, 이미지 3개 중 1개 Autosampler Node Troubleshooting (For New & Old Versions), Trigger autosampler with 6-pin connector: 6 단계, 이미지 3개 중 2개 Autosampler Node Troubleshooting (For New & Old Versions), Trigger autosampler with 6-pin connector: 6 단계, 이미지 3개 중 3개
    • Set the sample bottle to 12 for easier verification. And then press Enter.
    • Screen should say "Bottle 12 After 20 Pulses"
    • Plug in the 6-pin connector to the autosampler. The yellow LED should light up immediately.
  7. Autosampler Node Troubleshooting (For New & Old Versions), Trigger autosampler with 6-pin connector: 7 단계, 이미지 3개 중 1개 Autosampler Node Troubleshooting (For New & Old Versions), Trigger autosampler with 6-pin connector: 7 단계, 이미지 3개 중 2개 Autosampler Node Troubleshooting (For New & Old Versions), Trigger autosampler with 6-pin connector: 7 단계, 이미지 3개 중 3개
    • Touch the jumper wire to the LED attached to the white wire 20 times. This wire is for sending pulses to the autosampler.
    • You will see the pulse count decreasing on the LCD screen.
    • You will hear the autosampler making noises as it moves to bottle 12. You will then see the green LED flash 12 times to indicate the 12th bottle.
  8. Autosampler Node Troubleshooting (For New & Old Versions), Trigger autosampler with 6-pin connector: 8 단계, 이미지 1개 중 1개
    • You will see the LCD start indicating the sampling steps. Press Stop.
    • If these steps work as outlined, you have successfully tested the autosampler with the 6-pin connector and the autosampler is working correctly.
    • If the LEDs did not work or the sampler does not start the sampling process, something may be wrong with the autosampler wiring.
  9. Autosampler Node Troubleshooting (For New & Old Versions), Check wiring: 9 단계, 이미지 1개 중 1개
    • 8. Confirm there are no breaks in the wiring between the interface board the autosampler. See this tutorial for more details.
  10. Autosampler Node Troubleshooting (For New & Old Versions), Trigger autosampler with node battery.: 10 단계, 이미지 2개 중 1개 Autosampler Node Troubleshooting (For New & Old Versions), Trigger autosampler with node battery.: 10 단계, 이미지 2개 중 2개
    • Click here to watch a video of how to trigger the autosampler with the node battery.
    • Disconnect the relay board from the Open-Storm board.
    • Connect a red, black, and white jumper wire into the pluggable header (that was attached the board).
    • Connect a XX resistor in the same holes as the black and white wires. Resistors are blind to the polarity in a circuit. So you don't have to worry about installing them backwards.
  11. Autosampler Node Troubleshooting (For New & Old Versions), Trigger autosampler with node battery.: 11 단계, 이미지 3개 중 1개 Autosampler Node Troubleshooting (For New & Old Versions), Trigger autosampler with node battery.: 11 단계, 이미지 3개 중 2개 Autosampler Node Troubleshooting (For New & Old Versions), Trigger autosampler with node battery.: 11 단계, 이미지 3개 중 3개
    • Plug in the battery box into the autosampler.
    • Switch the battery box switch to "Manual Mode". Press the On button, then the Start Sampling button, then the Enter button.
  12. Autosampler Node Troubleshooting (For New & Old Versions), Triggering autosampler through relay board: 12 단계, 이미지 3개 중 1개 Autosampler Node Troubleshooting (For New & Old Versions), Triggering autosampler through relay board: 12 단계, 이미지 3개 중 2개 Autosampler Node Troubleshooting (For New & Old Versions), Triggering autosampler through relay board: 12 단계, 이미지 3개 중 3개
    • Screen should say "Bottle 12 After 20 Pulses".
    • Plug in the 6-pin connector, and connect the battery box to the node box.
    • Plug in the red and black jumper wire into the correct terminals of the 3.7V node battery. The. yellow LED should turn on immediately.
  13. Autosampler Node Troubleshooting (For New & Old Versions), Triggering autosampler through relay board: 13 단계, 이미지 3개 중 1개 Autosampler Node Troubleshooting (For New & Old Versions), Triggering autosampler through relay board: 13 단계, 이미지 3개 중 2개 Autosampler Node Troubleshooting (For New & Old Versions), Triggering autosampler through relay board: 13 단계, 이미지 3개 중 3개
    • Touch the white jumper wire to the red jumper wire 20 times. This wire is for sending pulses to the autosampler. You will see the blue LED blink with each touch.
    • You will hear the autosampler making noises as it moves to bottle 12. You will see the red LED light go on, telling us the autosampler is busy taking a sample.
  14. Autosampler Node Troubleshooting (For New & Old Versions), Triggering autosampler with node battery: 14 단계, 이미지 2개 중 1개 Autosampler Node Troubleshooting (For New & Old Versions), Triggering autosampler with node battery: 14 단계, 이미지 2개 중 2개
    • You will then see the green LED flash 12 times to indicate the 12th bottle.
    • If these steps work as outlined, you have successfully tested the autosampler with the relay board and the relay board is working correctly.
    • If the LEDs did not work or the sampler does not start the sampling process, something may be wrong with the relay board.
  15. Autosampler Node Troubleshooting (For New & Old Versions), Contact the Real-Time Water Systems Lab: 15 단계, 이미지 1개 중 1개
    • If everything else works, then there is an issue with the code/node. Contact the Real-Time Water Systems Lab for further instructions.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Brooke Mason
회원 가입일: 05/29/19
2,958 평판
안내서 17개를 작성함
Open-Storm Open-Storm 회원
Community
14 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 9
전체 시간: 202
