주요 콘텐츠로 건너뛰기
Autosampler Reset for Node Triggered Sampling (For Old & New Versions)
필요한 것
  1. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to manual mode: 1 단계, 이미지 1/2 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to manual mode: 1 단계, 이미지 2/2
    • To enable manual mode, flip the switch to "Manual Mode"
    • LCD screen will turn on
  2. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Restart the sampling program: 2 단계, 이미지 1/2 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Restart the sampling program: 2 단계, 이미지 2/2
    • Press On then press Start Sampling
    • Press Enter
  3. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Select bottle: 3 단계, 이미지 1/3 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Select bottle: 3 단계, 이미지 2/3 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Select bottle: 3 단계, 이미지 3/3
    • Press the number of the bottle you want to sample on
    • Press Enter
    • LCD should now show which bottle it will take a sample in
  4. Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to autonomous mode: 4 단계, 이미지 1/2 Autosampler Reset for Node Triggered Sampling  (For Old & New Versions), Switch to autonomous mode: 4 단계, 이미지 2/2
    • To enable autonomous mode, flip switch to "Node Trigger Mode"
    • LCD should turn off
    • If the autosampler is to be remotely triggered, avoid using the ON/OFF button to power off the sampler.
결론
Now the sampler is ready to be triggered remotely by an open-storm sensor node.
다른 한 분이 해당 안내서를 완성하였습니다.
Brandon Wong
회원 가입일: 01/16/18
502 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 396
