주요 콘텐츠로 건너뛰기
Autosampler Wire Connection Testing Procedure (For Old & New Versions)
필요한 것
  1. Autosampler Wire Connection Testing Procedure (For Old & New Versions), Setting up the multimeter: 1 단계, 이미지 1/2 Autosampler Wire Connection Testing Procedure (For Old & New Versions), Setting up the multimeter: 1 단계, 이미지 2/2
    • Make sure you disconnect the batteries completely before starting! Disconnect the solar charger, then the node battery and finally, the autosampler battery.
    • 1. Set the multimeter to the setting with the noise symbol (blue circles). On our version, turn dial to the noise symbol then press the setup button to display the noise symbol on the screen.
    • Your multimeter setup may be different depending on the brand/model.
    • 2. To make sure you are on the noise test setting. Touch the red and black lead together (yellow circle). You should hear a noise.
  2. Autosampler Wire Connection Testing Procedure (For Old & New Versions), Testing the wires.: 2 단계, 이미지 1/3 Autosampler Wire Connection Testing Procedure (For Old & New Versions), Testing the wires.: 2 단계, 이미지 2/3 Autosampler Wire Connection Testing Procedure (For Old & New Versions), Testing the wires.: 2 단계, 이미지 3/3
    • Be sure not to cross the leads when testing a wire so as to not short the wire!
    • 3. The following color chart shows which wire is in which autosampler connector pin.
    • 4. Place one lead in one of the autosampler connector holes (yellow circle).
    • It does not matter which lead is put on either end.
    • Place the other lead on the other end of the corresponding colored wire (blue circle). It can be either on the wire itself of the metal of receptacle holding the wire.
    • If the connection is good, you will hear a sound from the multimeter.
    • 5. Continue doing this for all of the wires.
    • Note, the green wire is not used.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Brooke Mason
회원 가입일: 05/29/19
2,928 평판
안내서 17개 작성하였습니다
Open-Storm Open-Storm 회원
Community
14 회원들
안내서 24개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 139
