주요 콘텐츠로 건너뛰기
Axe Empire 2.0 OLED Board Replacement
필요한 것
  1. Axe Empire 2.0 OLED Board Replacement, OLED Board: 1 단계, 이미지 1/2 Axe Empire 2.0 OLED Board Replacement, OLED Board: 1 단계, 이미지 2/2
    • Use an Allen key to remove four total screws.
    • 2.5 mm screws.
    • 1.2 mm screw.
  2. Axe Empire 2.0 OLED Board Replacement: 2 단계, 이미지 1/3 Axe Empire 2.0 OLED Board Replacement: 2 단계, 이미지 2/3 Axe Empire 2.0 OLED Board Replacement: 2 단계, 이미지 3/3
    • Press and hold the release button while lightly pulling the spring bolt out.
    • If the spring bolt has not been serviced with lube after a long time you might need to pull harder. This is a great time to lube the spring bolt.
  3. Axe Empire 2.0 OLED Board Replacement: 3 단계, 이미지 1/3 Axe Empire 2.0 OLED Board Replacement: 3 단계, 이미지 2/3 Axe Empire 2.0 OLED Board Replacement: 3 단계, 이미지 3/3
    • Remove the two main screws using a 2.5 mm Allen key to separate the air transfer plate from the frame.
  4. Axe Empire 2.0 OLED Board Replacement: 4 단계, 이미지 1/2 Axe Empire 2.0 OLED Board Replacement: 4 단계, 이미지 2/2
    • Remove the screw using a 2.5 mm Allen key and remove the foregrip from the frame.
  5. Axe Empire 2.0 OLED Board Replacement: 5 단계, 이미지 1/2 Axe Empire 2.0 OLED Board Replacement: 5 단계, 이미지 2/2
    • Use a 1.2 mm Allen key to remove the screw, and remove the cover to expose the OLED Board.
  6. Axe Empire 2.0 OLED Board Replacement: 6 단계, 이미지 1/3 Axe Empire 2.0 OLED Board Replacement: 6 단계, 이미지 2/3 Axe Empire 2.0 OLED Board Replacement: 6 단계, 이미지 3/3
    • Remove the last screw with a 2.5 mm Allen key to loosen the OLED Board.
    • Use a pick tool to carefully remove the battery and OLED Board together out of the foregrip.
    • Wear gloves in case battery is defective and leaking acid.
  7. Axe Empire 2.0 OLED Board Replacement: 7 단계, 이미지 1/2 Axe Empire 2.0 OLED Board Replacement: 7 단계, 이미지 2/2
    • Disconnect the battery from the OLED board.
결론
Christopher Ramos
회원 가입일: 10/05/21
345 평판
안내서 1개 작성함
CSU Los Angeles, Team 11-2, Grodsky Fall 2021 CSU Los Angeles, Team 11-2, Grodsky Fall 2021 회원
CSULA-GRODSKY-F21S11G2
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 199
