주요 콘텐츠로 건너뛰기
Axess SPBT1031 Speaker (Horns) Replacement
필요한 것
  1. Axess SPBT1031 Speaker (Horns) Replacement, Black Faceplate: 1 단계, 이미지 1개 중 1개
    • Look at the side of the speaker that has the red interface plate. Using a Phillips head PH1 screwdriver head, remove screws on the top and bottom of the black face plate. There will be one screw on top and one on the bottom.
    • Both screws are 0.55 cm in depth
  2. Axess SPBT1031 Speaker (Horns) Replacement: 2 단계, 이미지 1개 중 1개
    • Separate the black face plate from the tube by pulling them apart.
    • Be careful when pulling the wires apart or it will potentially damage the wires due to over stretching.
  3. Axess SPBT1031 Speaker (Horns) Replacement, Speaker (Horns): 3 단계, 이미지 1개 중 1개
    • By this point you should have determined which speaker needs to be replaced, to figure this out please refer back to the troubleshooting guide.
    • For the top horn replacement, you will be working with the blue and white wire pair.
    • For the bottom horn replacement you with the yellow and white wire pair.
  4. Axess SPBT1031 Speaker (Horns) Replacement: 4 단계, 이미지 2개 중 1개 Axess SPBT1031 Speaker (Horns) Replacement: 4 단계, 이미지 2개 중 2개
    • To remove the plastic coating around the desired horn, look on the back of the black face plate you removed and use the philips head ph1 screwdriver fitting to remove the two 0.3 cm Philips Head screw and washer combos on the left and right of the horn.
    • Screw depth of 0.7 cm
  5. Axess SPBT1031 Speaker (Horns) Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the horn from its fitting by pulling it. Position it in a manner that is easy to work with.
  6. Axess SPBT1031 Speaker (Horns) Replacement: 6 단계, 이미지 2개 중 1개 Axess SPBT1031 Speaker (Horns) Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
    • Use a soldering iron to heat the two contact points.
    • Then use a desoldering pump to remove the liquid solder.
  7. Axess SPBT1031 Speaker (Horns) Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the wires--blue or yellow wire depending on the horn you are replacing--from the old speaker and remove the speaker from the fitting location.
    • For the bottom horn replacement, you will be working with the yellow and white wire pair.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Elvira Lou Evangelista
회원 가입일: 03/09/16
957 평판
안내서 6개를 작성함
UMass Dartmouth, Team 8-6, Botvin Spring 2016 UMass Dartmouth, Team 8-6, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G6
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 7
전체 시간: 2,052
