주요 콘텐츠로 건너뛰기
Axess SPBT1031 Subwoofer Replacement
필요한 것
  1. Axess SPBT1031 Subwoofer Replacement, Subwoofer: 1 단계, 이미지 1개 중 1개
    • Look at the side of the speaker without the red interface plate; there will be a red ring around the mesh but no buttons on the side.
    • Remove the two 5.5 mm screws from the top and bottom of the black face plate using a Phillips #1 screwdriver.
    • Do not remove the plate yet.
  2. Axess SPBT1031 Subwoofer Replacement: 2 단계, 이미지 1개 중 1개
    • Use a metal spudger to remove the mesh speaker cover by wedging the narrow end into the center of the outer edge of the mesh touching the red plate.
  3. Axess SPBT1031 Subwoofer Replacement: 3 단계, 이미지 2개 중 1개 Axess SPBT1031 Subwoofer Replacement: 3 단계, 이미지 2개 중 2개
    • Remove four 5.5 mm screws from the red panel under the mesh using a Phillips #1 screwdriver.
    • For subwoofer replacement there will be four screws to remove and four bolts as well. The bolts are used for alignment and cannot be removed.
  4. Axess SPBT1031 Subwoofer Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • If the screws are difficult to remove, use the tweezers to twist and pick them out.
  5. Axess SPBT1031 Subwoofer Replacement: 5 단계, 이미지 1개 중 1개
    • Separate the red plate from the black face plate by removing the black plate from the tube and pushing on the inside of the subwoofer.
    • Be careful not to damage the black face plate or red plate as you pull them apart.
    • You may place the black faceplate back on the tube, but do not screw it back in yet.
  6. Axess SPBT1031 Subwoofer Replacement: 6 단계, 이미지 2개 중 1개 Axess SPBT1031 Subwoofer Replacement: 6 단계, 이미지 2개 중 2개
    • To remove the the wires from the subwoofer terminals, use a soldering iron to reheat the solder at each of the four points of connection.
  7. Axess SPBT1031 Subwoofer Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
  8. Axess SPBT1031 Subwoofer Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the old subwoofer.
    • Connect the brown wires to the positive terminals and the black ones to the negative terminals when re-soldering.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Elvira Lou Evangelista
회원 가입일: 03/09/16
957 평판
안내서 6개를 작성함
UMass Dartmouth, Team 8-6, Botvin Spring 2016 UMass Dartmouth, Team 8-6, Botvin Spring 2016 회원
UMASSD-BOTVIN-S16S8G6
3 회원들
안내서 8개를 작성함
1가이드 댓글
I Ned to replace the charger conection and I need the parts please u can email me at elpaleterolopez@Gmail.com or call me at 6613402547
Ramon lopez - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 1,823
