주요 콘텐츠로 건너뛰기
Axess TA2513-10WT Back Cover Replacement
필요한 것
  1. Axess TA2513-10WT Back Cover Replacement, Back Cover: 1 단계, 이미지 1/1
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Back Cover Replacement: 2 단계, 이미지 1/3 Axess TA2513-10WT Back Cover Replacement: 2 단계, 이미지 2/3 Axess TA2513-10WT Back Cover Replacement: 2 단계, 이미지 3/3
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Back Cover Replacement: 3 단계, 이미지 1/1
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Back Cover Replacement: 4 단계, 이미지 1/1
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Hayley Rabe
회원 가입일: 03/24/15
125 평판
안내서 1개 작성함
Baylor, Team 6-3, Shaver Spring 2015 Baylor, Team 6-3, Shaver Spring 2015 회원
BU-SHAVER-S15S6G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 256
